Behringer MX 1604a, i need more outs, what effect will useing a dual or Y output adapter have on the signal? any? lower? your pro config suggestions and oppinions please...
thanks...
thanks...
terrible_buddhi said:where are the outs going to? I have done this for headphones and stuff, and yes there usually is some degradation of signal.
cstockdale said:If you put a channel splitter on each output (ie an A/B/Y splitter) then it will feed both/or either one with no signal loss, but you would need 4 of these, which adds up in $$.
Maybe you need a patchbay.... or a new mixer
Bulls Hit said:Does that mixer have inserts?
If so you might get extra outs that way
Fusion2 said:
i have 2 systems running m-audio 410's and would like to see if both can have equal rights to the little mixer...
Garak said:Also their may be some frequency response issues but we haven't covered that yet in class
(I'm an electroincs engeering technology student)
13th_Omen said:so what do you need these extra outputs for?? you may not need what you think you need if you could explain your project a little more in depth!
i'm attempting to give each system equal rights to the mixer
13th_Omen said:what do you mean? are you sending each channel to a seperate track on an ADAT or something? i am pretty sure your inserts will suffice.
