What will happen if I remove the Ground on the 3 prong plug? I'm using Yamaha MQ802.
THanks!
Our home doesn't have a grounding system.
What will I do?
Until 1962 in the US, ungrounded, unpolarized Duplex receptacles were commonly installed in homes. The ground (earth) rod or tying to the galvanized, steel water pipes was commonly used for the ground loop, at the service entrance. I would advise against using the water pipes... it can lead to a shocking, drink of water.
D
Are you telling me that there is no earth connection in the whole house? Call an electrician, the mixer is the least of the problems. Where are you? What country are you in that the house has no earth?
alan.
Philippines. XD. I'm just 16, I think my parents won't agree if I tell them to call an electrician. =)
Are you experiencing noise when recording ? Just curious...
