TalismanRich
I got the new mic set up and tested. I didn't have tons of time, so I did a quick acapella vocal of No Moon At All ( I had Diana Krall playing earlier while doing housework - it turned into a bit of an earworm ). Then a quick 15 seconds with a cheapo tambourine that came with my Woodstock Directors cut. I use this to listen to the high end transients, kind of like the "shake the keys" test. I had the 47jr and the NT1 both set up as closely as I could get them. I was about 18" away on the vocal and probably 24 inches away on the tambourine. The tracks are raw, no EQ, compression or anything other than to normalize them all. Sensitivities are different and I didn't spend a ton of time trying to balance the inputs.
I had done FLAC files, but alas, HR doesn't support uploading of FLAC. So instead, you get 320K mp3. The original wav files are 88K/24bit and I felt they were too big.
Give them a quick listen and let me know what you think.
