geneticfunk
Can Cubase, or any other app in conjunction with Cubase, do the following?:
I have a MIDI fader on CC#0, and MIDI drum pads transmitting various note #'s. I want to make the MIDI data from CC#0 be routed to the CC# that matches the last played note #.
For example, let's say I play MIDI note #1. I want the MIDI data on CC#0 to be routed to CC#1. Let's say I then play MIDI note #2. I want the MIDI data on CC#0 to then be routed to CC#2 (but no longer to CC#1.)
If I play MIDI note #1 again, I want the MIDI data on CC#0 to be routed to CC#1 again (but no longer CC#2).
And so on, for every MIDI note number.
I called Cubase tech support, but they said that Cubase cannot do this. Is there any MIDI routing program that I can use in conjunction with Cubase to make this happen?
Thanks, any help is much appreciated.
If anyone's interested, the reason I want to do all of this is because I am using an Akai MPD16 MIDI controller to control Native Instruments' Battery Drum Sampler. The MPD16 has one MIDI fader on it. I want to use this MIDI fader to control the volume of the most recently played drum cell in Battery.
