MistaMash'dup
When I play my VST sampler using a MIDI controller, there is no noticeable latency. However, if I record the MIDI controller's MIDI output into Cubase, my whole MIDI recording is shifted about 57 milliseconds ahead of where it should start. This makes it out of sync with whatever I was playing the MIDI controller along with.
I had a similar problem with audio recording latency, but I solved it by using the "Record Placement Offset" feature to compensate for the latency. Is there a "Midi Record Placement Offset" feature that I can use similarly to solve my problem?
Or is there a better solution out there?
Any help's appreaciated
