I was wondering what a good keyboard interface would be for a beginner. Keep in mind I am NOT a keyboard player. I am a guitarist and just need it to add "synth" instruments to the mix. There is a huge range in price. I don't really know much about this subject.
Thanks Pat
Didn't get it. It was sold before I made up my mind.
Found another one for 10 dollars more though
Because I'm such a clunk handed keyboardist that can't play keyboards, I couldn't even think of any keyboard with less than 49 keys. I've long wondered how players can get by with 25. They obviously know something my brain won't even consider !esp the 25 key version
Okay I got the keyboard hooked up it seems to work but there is a delay. How do I get rid of that? I have Sonar X1
I have an interface. Scarlett 8i18 Could it be that I'm using a USB cable to the computer since I don't have a MIDI cable? Maybe I can pick up a MIDI cable on the way home from work today a and connect to my interface
Ho Kay!
Just rigged my Ek49 to this ancient 3G P4 running XP Home.
Plugged up the Scarlet 8i6 and ran Pianoteq* demo.
With 10mS set on the 8i6 USB control panel no delay that I could detect. Whacking the time down to 1mS produced either crackles or nowt. 5mS seemed ok.
So, make sure the AI is set with ASIO drivers and if there is still a delay you must have a big buffer setting lurking somewhere in the system.
There is no difference in my experience between a keyboard connected via USB and one connected via DINs to an AI (THEN connected via USB!!??) And I would not expect there to be since MIDI is Sooo slow compared to even USB 1.1.
*This is worth downloading even if just for test purposes. It makes setting a MIDI input and output device very simple and gives access to the AI's control panel without searching for it.
That said! Get a couple of MIDI cables anyway!
Not sure if we are saying the same thing, if it is USB to USB, you're right, should not be an issue. What I have seen is MIDI DIN to USB, there is a translation that takes place. I guess depending on the cable manufacturer and how well they convert the data could be the major area that is the potential problem.
