Hello All,
Because I am a fool I have a new found curiosity for mixers controlled via midi. I stumbled across the Fostex DCM100 which is a very simple 1U mixer that, beyond a simple gain control on the front panel, is controlled via a small midi surface called the Fostex MixTab. The mix tab has AUX levels, EQs, Faders, ect., and can control up to three DCM100s.. pretty cool technology.
Finding the DCM100 is not hard, a half dozen or so sit on ebay all time and sell for around $50 it seems.. the problem is the Mixtab seems to be rarer than hens teeth...
Who else was making units like this? I've seen a few Tascam's with mute automation that could be run via midi but never as powerful as this Fostex System.
I'm not suggesting anyone should run out and buy a complete system or anything but frankly.. you could pair this up with a DAW and setup a mix system that could handle 24 stereo pairs with EQ, Pan, Aux send and level automation... complete insanity!
More to my point... with a few MixTabs and DCM100s you could setup a cheap and fairly simple way to let the artist control their own monitors. All you would need to do is send a pair of MIDI cables out and a headphone line from the mixers...
Anyway... Just thought it was interesting and wondering if anyone else was doing something similar...
Robert
Robert
