John Willett
Circle Sound Services
The few times I have mic'ed up a Stienway 9 foot grand successfully we used a spaced pair of u87's about 1.5 feet above the strings on either side. Nothing fancy. That gave me a nice close sound without too much room (we were in a very large room). This worked well for the pop mix we were doing at the time.
Agreed, good for a pop mix.
When I used that same piano in the same room to capture a more realistic sound from a listeners prospective we used a pair of c414's about mid piano just outside the opening in Mid Side configuration. This gave us a AWESOME sound which i prefer. Very natural and easy to control room sound by bringing in or out the mid side. This is great for making a chorus wider sounding.
If it were me with your microphone selection I would try the SE4400a pair in MS. I would use the c214 spaced pair as a alternative method. If you have the luxury, do all 4 mics and a/b both! IMO that piano would be better suited for LDC over SDC. YMMV!
Sorry, I don't agree with this.
MS is an excellent technique and I use it a lot - just not for a concert grand piano.
You would likely use a cardioid mid - the result would be a recording lacking in bottom end compared to using omnis.
Yes - I tried this myself when I had to record a Steinway Model-D in a small room.
I had the chance to do a test a week or so before the recording. I tried 20cm spaced omnis and an MS pair in various positions in the room to see what it all sounded like.
I was amazed at how much of the bottom end was lost on the MS pair compared to the omnis.
In the instance that the OP describes - recording a piano recital in a good room - the Røde NT-55 with the omni heads is by far the best option.
I'm sorry to keep repeating this, but it's true - many of the other microphone techniques suggested are actually very valid techniques. But not for a classical piano recital in a good room.
You need to use the room and get the best balance between the piano and the room and good SDC omnis are the perfect solution for this.
Remember - this is a location recording, not a studio recording; with a great room you use the room. It's not a studio where you have to lose the room and artificially put in the room by using reverb. The reverb is natural in the room and you get the correct level by mic. placement. With a good piano recording that's all you do - get the mice in the right place, record and edit; there is no need to add reverb, no need to EQ and, most of the time, no need to compress - just put out the mics record and edit, that's all.
