H
Hot Rocks
Hope someone can help me,I just bought a used Teac Tascam Series1 8 channel line mixer that I figured I could use with a Tascam 238.I plugged a mic into the mixers channel ones rca input useing a 1/4 inch to rca adapter to hook the mic into it and have found the gain control on the mixer is useless.The pan moves the signal around fine but neither the channel gain nor the master gain has any effect on controlling the amount of signal I want to put on the 238's track.Is there somthing wrong with this mixer or is it the wrong kind or am I doing somthing wrong ? I also took recorded material from the 238's output and sent it into the mixer then back out to another open channel on the 238 to see if the channel gain had an effect on controlling the outgoing signal. it didn't. The headphone is full of stactic
