@DaleVO & PRHunt : Is that poctop's? I have the tapered PCB set, I am pretty sure they fit in a MXL 2001 style. I don't know about the SP-1. I'd have to check, and most of my stuff is under tarps right now. If you use the square set, another guy chunger sells these big bodies for thos (SYT-3 I think)
@PRHunt: Does the Peluso work the same way or come the same way with four wires and the "RK-87?"
@DaleVO & PRHunt : Is that poctop's? I have the tapered PCB set, I am pretty sure they fit in a MXL 2001 style. I don't know about the SP-1. I'd have to check..... If you use the square set, another guy chunger sells these big bodies for thos (SYT-3 I think)
Are you looking to use the Peluso K-87i capsule? Peluso Microphone Capsules. I think I am leaning toward the RK-87, but I am still researching.
Dale
@DaleVO,
BTW, I have some extra "OEM" "K47 style" capsules left over from a mini groupbuy if anyone is interested. I also have a few single and dual sided 32mm K67, if you needed for a "proof of concept"
@DaleVO, poctop's tapered boards are exactly the same size as RuudNL's SP-1 boards. The screw holes are about 4mm lower, though. I wouldn't expect that would be a problem.
