I record at home using Cubase, Audition, and Ableton Live, and aside from MIDI, everything I record goes through an MXL 2003 Condenser Mic. This is then sent to my Behringer Eurorack 602A Mixer, and then into my Computer. The question I have is this: You obviously don't want a hissing noise in your recordings, so what is a good volume/decibel level mics should be used at? In Audition for example, the decibel reading can go from 0 all the way to -72, but when I record, the "hissing" the mic picks up during silence is usually around -30 to -40. Is this adequate? or should "silence" levels be even lower. I should also note that although my room is not soundproofed, I do not believe much of this hissing is coming from the surrounding environment.
Thanks,
j
Thanks,
j
