jameslucas
Any ideas about how much I could get a decent mic preamp for. Looking at $0-$200 if I could. I've got a behnringer mixer but there is some noise on the high end so....any ideas?
jameslucas said:I've got an sm57 and an sm58 which I plug directly into my behringer UB1202. I don't use the EQ on the behringer either. I then run the RCA Tape out from the behringer to the RCA line in on my sound blaster audigy card. I set the gain stage on the UB1202 at about 80% and then I have to boost the tracking software to get the correct volume. I don't think it's a problem with room noise, I think it's a problem with gain staging. ideas?
jameslucas said:Any ideas about how much I could get a decent mic preamp for. Looking at $0-$200 if I could. I've got a behnringer mixer but there is some noise on the high end so....any ideas?
Recording Engineer said:Mackie VLZPRO preamps work great as filler preamps (as long as you don't crank them) and it stops there!
If you can afford it, stay away from Mackies as a mixer... The EQ kills the signal and eats up headrom like crazy! And there is no headroom to even speak of in the first place on the buss and main mix amps!
Since I've had the Mackie, my mixes tend to have this "limited" "sound" to them, no matter what the style of music.
