Live, it's going to be the same issue that you'll always face - maximizing the sound source signal relative to the mains output by proper gain staging, mic posititioning, and speaker positioning. The higher gains you're using, the more tricky it will get to make it all work, but keep in mind that you may not need nearly as much gain as you might think to make the effect work.
