Yesterday I replaced the IC sockets on the Bias boards as well as six electrolytic caps and one burned resistor. I also did a slight modification to the audio mother boards to allow me to use white LEDs for the meter lights since the 7387 bulbs are stupidly expensive from what I could find.
The mod was simply removing a section of circuit board trace and soldering in some 8.2k resistors. The LEDs still fit in the original bulb sockets which is nice.
After reinstalling all the boards, I was upset to find that the machine would not go into record mode. That is, until I realized that the problem was having the switches in "safe" mode.
Once I fixed that mistake, the machine recorded just fine. Although a little intermittent at times, likely due to dirty connectors. I think some conductive grease applied carefully to each connector lead may be what is needed to keep from having to wiggle connectors all the time.
Even after cleaning the connectors with Deoxit, I'm still having troubles.
But those are only small troubles compared to what is happening now. Or rather, not happening.
I have no left meter response and weak and distorted audio on the left channel. It went sort of haywire cutting in and out and then more or less nothing.
I have a feeling something is fried and all I know is that it's not on the repro board as swapping boards around changes nothing.
Just when things were going so good. This has really got me down.
