Thanks for that link, Bruce. Just printed it out for some light weekend reading.
I go through what I call "imitation mastering" on the stuff I work with. Basically, since all my recordings are live performances I try to get the best mixes I can while still creating a disc that sounds like a live recording. My mixes go straight from my mixer into my PC where they are recorded in a 2-track editing program. Once there, I review the waveforms for any stray spikes that are out of character with the rest of the song and apply some gentle compression to bring them in line. I then go through a volume maximizing process to bring the level up without going into digital clipping and maintaining the dynamics of the original as much as possible (no brick wall limiting for me). I use this process to balance the levels between the different songs. If I intend to have no audible breaks between songs I mix the whole set at once and do the above to the entire set as one waveform (mixing a 30 minute set continuously can be FUN, over and over until you stop forgetting that one spot that needs to be muted because someone kicked a mic stand). Then I place markers to split up the tracks.
As I said this is a pale imitation that is only a small piece of what is considered real mastering. It does what I need, and the results are pretty good usually (as long as the material was good to start with and my ears are working). I don't have a good way to apply any outboard EQ at this time, and I don't like what I get with the software I've got, so I rely on my mixes to be EQ'd as well as possible from the board. This is an approach that can be utilized by a homerecr, but it has taken me 2 years to finally start getting the quality of results that I want, and those who are listening to what I'm doing are fairly pleased with the results.
Anyway, just thought I'd drop this in. Mastering really is an art form, and I hope someday I'll actually get to go through the process with a pro just for the education it will provide.
Darryl.....
