I am in the process of mastering some digital tracks for a band. The tracks are stereo. They have a good
solid mix. My plan was to finish the mastering digitally in Logic Pro, send that output to tape and bring it
back into the DAW.
I went through the process adding any necessary compression and eq. The final stage was limiting and I had a good compromise where the songs were not really slammed to the max. I checked the output wave form and was pleased to see some dynamics. Of course there were some good steady 0db peaks at times throughout the song.
Now, onto tape the limited version goes. The chain is Logic Pro -> Tascam FW1884 convertors -> Tascam M2600 analog mixer -> Tascam 42. The Tascam 42 was bias adjusted again for RMGI SM911 tape.
I set the recorder to average between +1 and +2 VU recording. Recorded the tunes and playback sounded great. It definitely took some of the digital harshness away.
As I recorded the output of the tape back into the DAW, I looked at the wave form and it was noticeably lower in volume. I thought, well this is OK because we just need to bring the level back up to zero, no big deal. I added the gain back digitally, but now it was overloading at key points in the song. In order to tame it, I had to bring the level back down to keep the peaks at 0db. But that lowered the volume of the whole song again, like it was never limited to begin with.
Scratching my head, the only way I was able to correct this issue was to add another limiter on the final file that was recorded from tape, thus taming those peaks yet again. Now, it does sound good but....
Is there something wrong with my signal chain or procedure?
Why are overloaded peaks even being recorded on tape (or played back) when they were limited to begin with?
Still learning.... thanks for any input.
Mike
back into the DAW.
Mike
