Hi,
I have been mixing for about a year now and on my master buss/stereo mix
usually just end up cutting some low frequncies, no compression. Once I mix
otb with my folcrom was considering buying an ssl stereo compressor and
adding it in the signal chain before i go back to my DAW. I know some people
use compression , some don't and some people use slight eq as well.
My question is what kind of settings do you find yourself using for the comp
and eq? Any standard settings you find youself going to that sounds good
like 2:1 , -9 threshold fast or slow release times or boosting around 15k
Thanks
Thanks
