W
		Wonka
I probably did everything wrong.  But I did the best I could with what I  have.
https://soundcloud.com/cadillacbob/maryjanecompressed
Comments welcomed
New to home recording.
Current work flow.
Tascam DP-008 - only records 2 tracks at a time. Only using the 2 omni directional condensor mics that come on the DP-008.
Input A & B almost set the same. Just a little differences in Pan off center.
Acoustical guitar and vocals.
Create master file in Tascam. Vol, pan, and reverb set once master is created.
Connect Tascam to computer via USB. Comes up as another drive.
Bring mastered file on Tascam drive into Reaper.
Applied some compression in Reaper. -20.0 / Ratio 3/ Auto-make-up checked.
I know this is recorded loud. Reason - You can turn sound down but you can't turn it up.
Comments welcomed
Current work flow.
 Maybe it's happening at the input stage.
