You can use either balanced or unbalanced cables to connect your amp's direct output to your interface's input.
Balanced ins and outs are for controlling noise on longer cable runs, and they are compatible with unbalanced cables and connections. Using an unbalanced cable simply does away with the noise-cancelling signal but retains the original signal and shielding.
One thing you'll probably have to consider when combining direct and mic'd signals is you might need to flip the phase of one of the signals, adjust your mic position, or fiddle with the phase alignment in your software. This will help compensate for the mic'd and direct signals arriving to "tape" at slightly different times.
Im gonna go with unbalanced.
Does the amp have a balanced output?
How much of an issue is that really? I don't have "practiced" ears so maybe I just don't pick up on it but curiously enough I was trying some stuff last night that begs that question. I just picked up a Reissue Plexi and have recently gotten some new mics as well so just to do some comparison shopping I set up 4 mics and a direct out from the Hot Plate and recorded 5 tracks of the same guitar bit. The mics were placed differently; 3 dynamics right on the cab and a ribbon a few feet off, and I couldn't hear any phase issues with any combination of tracks played back. Am I not hearing something I should be or did I just get lucky? The worst part is deciding which single or combination sounds best!... the mic'd and direct signals arriving to "tape" at slightly different times.
lou
Well if I did I never posted just to say so.Didja ever want to add to a thread, but before you read all the posts already in it, forget what you wanted to say?
lou
