ok norm.
one thing to remember is that any wiring work done now that is not certified and pat tested will make any isurance invalid should an electrical fault or fire take place. the regulations changed in the uk so be careful.
first you want a dedicated trip board for that section of mains input, this will protect you from shorts and faults and power spikes, this will also handle the mains distribution to as many sockets as you need.
if you are running the cable along the roofline or gables than buy some conduit, get some of the white pvc conduit that has a clip on and off face to it the whole length of the "u" channel conduit, this aids in inspection and futher cable runs. where ever you need to drop a socket you just fit a "T" piece inline of the conduit run and drop down with a section of thinner conduit and a plug socket finisher. label each socket to its corresponding trip on the board also.
if you do this then the cables are all no where near your audio cables.
sit down and try to draw up the layout of your equipment, list how many items will need power sockets. try and make a visualised drawing of who it may look in plan view" from the top down" and position the sockets in such a way, your audio cables can then be v-strap tied these are velcro reusable ties better than the plastic pull zip ties that you have to cut away.
also try to use ofc balanced audio cables where you can, if you buy cheap nasty audio cables then that will effect sn quality also.
i hope that helps start you off, i can put some links up for info on the trip distribution board, conduit and junctions if you want them.
