Thanks Beck.
I didn't know you should warm up a machine by turning it on at lease 15 minutes before recording.
Thanks Beck.
I didn't know you should warm up a machine by turning it on at lease 15 minutes before recording. Thanks for that extra little nugget of info.
When you say "release the tension on the tape so everything is at ease" what do you mean exactly?
So does the same thing apply to cassette tapes at all?
The 244's capstan spins continuously if there's a cassette is, so I guess this means, leave the machine on, take the tape out!
It's always kind of bothered me since capstan motors for the MS-16 are super expensive and never come up.
Tascam...the Rolls-Royce of analog recording...?
Rolls Royce jet engines are also super expensive and most of the airplanes they're attached too rarely fall out of the sky. Maybe there's a correlation there you're overlooking!
I see what you did there!
Do you have something against the MS-16 capstan motor?
the MS16 capstan motor, is a brushless design. They run much longer than the brushed motors. The Tascam 42 also has an always running capstan. It maybe possible to modify the machine to make it stop when not in play.
