I just got this card and find it's levels quite a bit lower then my standard Soundblaster Live levels, is this typical? and yes, i have the volumn turned up all the way.
Ummm, how about some more details????? Is the level too low recording? Playback? How is it plugged in? The Delta 66 (I have the 44) only has line inputs, so if you're plugging a mic directly into it, it will sound like cr*p.
> it's levels quite a bit lower then my standard Soundblaster Live levels <
This is easy to fix. Go to the Delta control panel and tell it which of the three input and output levels you want: +4 Pro, Consumer, or -10. (You probably want the last one to match an SB Live.)
