I record (mostly synths) directly into Cubase - however I read somewhere recently that instruments like basses and kicks carry a sweep of very low frequencies which, though inaudible, can push your mix into the red and therefore cause a reduction in volume when you lower your levels to compensate.
Is this true?
If so, should I export my basslines etc. into a Wave editor and run parametric Eq (Sound Forge EQ options to 'remove low and inaudible freqs' and 'remove low-freq hiss and rumble') or is it all much ado about squat?
Regards
Klytus
Is this true?
Regards
Klytus
