M
		Mike Freze
Just bought Reaper and love it compared to Cubase LE I was using.
I am experimenting with creating audio samples from pre-recorded songs. Hope to create my own one day playing my own instruments.
I took the beginning opening drum pattern from The Rolling Stones' "Honky Tonk Woman" and copied/pasted it to a different track. Sounds good (it's only like a half measure segment). When I copy and paste my segment to repeat the pattern in the same track (kind of like looping), I play it all out and it sounds good timing -wise. But every time it goes from the very end of one event and plays the next identical event, there is a slight stop and a brief clip sound between the repeated patterns.
How can I smooth this out? I tried using glue, nudge, but the slight delay and clip is still there between repeated segments.
I also tried using the "toggle/repeat" function on just one event for continuous play. Same thing: each time it goes back to repeat, there's that slight delay and clip when it goes to repeat. Not a lot, but definitely noticeable.
Any suggestions? Thank you.
Mike Freze
Mike Freze
