My Two Cents on Choosing a Mac Recording Rig
Aloha DJBC,
There is plenty of great back and forth info in the previous posts to help you form an informed opinion. Good arguments for both simple and complex rigs.
My thoughts, based on recent experience and three years of prior research.
- No matter which rig you put together,
dedicate it to recording only. DO NOT do any everyday computing on it or problems will arise. Read the section on maximizing computers for DAWS in the "computer" section at gearslutz.com.
- Your $5K budget can provide you with any model of Mac in a great combo that you'd want to start with. I suggest you start out one of the iMacs. The Mini is great, but it does not offer a 500 GB 7200 rpm HD and you'd have to increase the RAM anyway (limited to 4GB's on the mini). Upgrading that would take your price up from $600 to nearer $1K. Better to get one of the iMacs which already has those in place and offer much more - the basic model is just over $1K right now. Depending on what your goals are the Mac Pro may be unnecessary spending with features you don't need at this time. If you're new to computer recording, KISS - keep it simple. There's a steep learning curve at first.
- Your choice of rig and computer will depend completely on whether you're going to be building mega tracks in large projects or are just looking to record two tracks at a time - or something in between. Type of music? Pro or home studio? Midi? Software instruments? Loops? Third Party Plug-ins? Answer those questions before you buy and this main one:
What are your recording goals?
IMO, go with an integrated Mac system. Get one of the new iMacs (the new i7 Quad Core iMac may be overkill at $2.2K). Dive in with
Logic Pro 9 as your DAW. Get an Apogee Duet or Ensemble interface (much better in everyway - pre's, conversion and clock - than anything from MOTU for sound quality). Get an external firewire hard drive for project storage such as the Glyph 050Q from Sweetwater, the best with the best warranty.
Apple and Apogee have fully integrated the software and hardware into this combo. YOU CANNOT BEAT IT FOR SOUND, SYSTEM COMPATIBILITY and STABILITY in a basic Mac rig! I know, I tried ALL of the DAW's including PTLE before buying the Mac/Logic/Apogee/Glyph rig. And it would work well within your budget.
A Mac Pro would eat up your budget. But it could be necessary once you answer the questions above. If you're new to recording, or have simpler goals you do not need a Mac Pro yet.
- Pro Tools LE is an error-prone program. Pro Tools HD ($14,000) is the best DAW and the Pro Tools most often referred to when talking about the "industry standard." In my experience, LE is a limited PIA that's not even close to HD or Logic, IMO. Logic works better (fewer errors) with Macs.
- Don't get used to Mac's free DAW Garageband workflow and then try to move up to Logic if you want pro sound results and less hassles. If you haven't used a DAW previously, it's better to go right into Logic so you don't have to break established habits later - no matter how GB is designed as a stepping stone to Logic. Although not perfect & with bugs of its own, Logic is not a "light edition" DAW like PTLE. And its got more features than any DAW on the market.
Once you get the basic setup, and put the time into learning Logic Pro, and really get going, then you can build up your rig's front end with great boutique or vintage mics and pre's - which is where the best money should be spent in recording, IMO. Or try other interfaces like Metric Halo or PCI cards for lowest latency.
Finally, it won't be too long before Logic is full 64-bit. We're all waiting for them to get off their okoles on that one!
Just my opinions, friends. Good luck with your research and purchases, DJBC.
A Hui Hou!
alohachris
