H
hairylarry
Hi,
Anthony asked me a question about dynamic omnis so I thought I'd post my answer. Please add your thoughts on omnis. When you would use them and how. Also any additional history of omnis in audio recording would be cool.
The EV RE50 and the EV 635a are really the same mic and they are the workhorses for video studios, ENG, interviews, etc. The 635 is still in production so that keeps the used cost down. $50-$100. Great mics. Used to record vocals, cabs, etc. on many hit records. Also omnipresent on the Lawrence Welk show which did have great production values whatever you think of the music.
I like the RE50 clones, Realistic 1070 b,c, or d. Or a step up would be the EV PL9s or EV RE55s. The Radio Shack mics were made by Shure in Mexico and they have an extended frequency response and a midrange bump compared to the RE50s. The RE55s were often chosen by high end European recording companies when recording symphonies direct to disk. They are an extremely flat wide frequency response omni. The PL9s are similar to the RE55s but are less expensive.
I do a lot of recording outside and wind noise is always a factor. I will use a pair of omnis as a spaced pair and put foam windscreens on them. This setup gets the least wind noise of anything I have tried.
I also use my omnis recording acoustic guitar where I can place them very close to the strings without any proximity effect. And I have used them for recording vocals or horns. They are also great for cabs. Doing live music you can just hang them down in front of the speaker looping the cord through the handle and they will do the trick.
Generally speaking a pair of omnis are your safest bet for recording stereo in unusual conditions which is why they are the field recorder's first choice.
I know they're not fashionable anymore but I use my omnis all the time.
I also have a pair of Naiant condenser omnis that are just superb and I will sometimes choose them over the dynamic in a controlled setting like a studio. Another good way to record stereo with omnis is a Jecklin Disc. X-Y stereo recording doesn't work well with omnis. The X-Y technique is for cardiods.
Thanks,
Hairy Larry
Thanks,
Hairy Larry
