Hi,
I have a little home studio with a few condensers/dynamics etc etc running into a yamaha mg10/2 mixer which I use simply as a glorified preamp. I then run the -10 outs from the mixer into a live card (running kx for asio) with good results.
My only comlpaint with this system is that my PC is in the same area as my recording area so I therefore get PC fan noise in my recordings. Not good.
So my plan is basically to have the PC in a different room and run long cables to my recording room. I will have the keyboard/mouse/monitor in my recording room but the actual PC itself in a different room.
Now for the PC cables (mouse/keyboard/monitor) it's not a problem to run them a relatively long distance (10ft).
However seeing as my connection from my mixer to the PC is simply a 2xRCA->3.5mm I am worried about noise.
Do you think that alot of noise will be introduced by having a run this long (not near any high current cables, simply running with the other PC interface cables, no power)?
Or do you think the better option would be to have a usb/firewire interface connected (via extension cable) to the pc and have a really short run from the mixer to the interface?
Thanks guys,
-Dan
Thanks guys,
-Dan
