I don't post much, but read a lot. Now I have a question. Hope I can get some knowledge here.
I own a xenyx 2442fx mixing board http://www.behringer.com/EN/Products/2442FX.aspx
It does not have mono out and I'd like to run in mono so the on-board effects don't ping pong between the left and right mains.
Here are two responses from Behringer that contradict each other a bit:
1. Are either of the main outs able to be mono? With some equipment, the left jack is mono. I don't like the delay effect ping-ponging left to right. Thank you in advance.
response
You can use either the left or right output as a mono signal. Just make sure all of the PAN knobs on each channel are straight up so none of the channels are panned left or right. As far as the FX, you might want to try one of the other delay FX presets that don't bounce from left to right. Presets 50 - 59 are all delay type presets. 88 - 99 are delay combination FX.
2. I do not want to run my xenyx 2442fx in stereo. There is no mono out.
Is there any reason why I can't run stereo main out into a "Y" adaptor to 1/4 inch mono, and into my power amp for parallel use?
response
Yes there is a good reason not to do this...Phase Cancalation..you will lose sound and sound quality.
Use the Left main output with all panning to the Left, let me know if you have any other questions.
Sorry to kill you all with too much information, but my ignorance makes me do it. Any thoughts or solutions would be welcome.
peace
response
response
peace
