Never liked using electric acoustics. Would much rather mic the guitar.
That'll change when you find you can't get even close to enough level from a mic before feedback. It might not happen at this gig, but it will sooner or later.
Key points of live mic technique:
1. Inverse square law. The closer something is to the mic the louder it will/can be. You get 6dB of gain by halving distance to the mic. If bleed or feedback is a problem reduce the distance between the mic and the source and lower the gain.
1b. The closer someone sings to the mic the more sensitive it is to small movements. If he backs off an inch from the lips-on-grille position you lose a lot of level. If bleed and feedback aren't problems (acoustic coffeehouse type gig) consider having him stay 6" or so off the mic, and use a cardioid rather than a super- or hyper-cardioid mic. Then the singer can move around, look at the fretboard etc. without large changes in level.
2. Proximity effect. With directional mics the closer you get the more bass and low-mids you get. You can use this to your advantage in combination with the above. If the singers are singing lips-on-grille you can be fairly aggressive cutting lows and low-mids to get back to a natural tone, and as a byproduct greatly reduce plosives (booming P and B sounds).
3. Polar pattern. Know what your mics' polar patterns are. With vocal mics aim the null of the pattern at the wedge. For cardioid mics with the null 180° off axis tilt the mic up and put the wedge directly in front of the singer. For super- and hyper-cardioid mics either set the mic flat and place the wedge directly in front, or tilt the mic up and move the wedge about 30° to the right or left of the singer. Also take advantage of polar pattern when micing drums, either to include or exclude multiple sources in one mic.
4. Use fewer drum mics when possible, or be ready to turn them down or off in the mains. On a small stage the vocal mics will be your overheads. Just do kick and snare mics, and maybe toms. For reggae a dedicated hihat mic may be required. If the snare is too loud don't put it in the system, but if you have a board with groups you can leave the fader up without assigning it to a bus and use the channel to trigger some reverb. My habit would be to mic the whole kit up but use only what was needed.
