You just need to configure the outputs in Cubase. You can send any track (or group of tracks) to any output. It has nothing to do with effects sends. It's all in the manual.kubeek said:Ok I will try that.
I have another question, I have 8in 8out soundcard, and I want to route the tracks to the outputs, eg. recording headphones, monitoring and so on. Is there some plugin that could do it? I don´t want to do it manualy through the effects busses.
It's right next to the any keynoisewreck said:Does Cubase have a mixdown button?
Most of the time, you can't. You can only use one asio driver at a time. Even getting two of the same cards to work together is a pain because you have to syncronize the clocks. Soundblaster has no provision for this. (and should never be used for audio in the first place)kubeek said:I have another question:
I have the 8+8 soundcard controlled by the supplied asio driver, and I would like to use also a Soundblaster card as another input/output. How can I do that?
