You guys have been so helpful in me getting my gear together and I just wanted to start out by thanking you! This site is an invaluable resource not only for the information that is provided but also due to the helpfulness of all you guys. So thanks!
In another post, I mentioned I started doing the sound for my partners celtic band. They perform in a medium size bar which already has mounted speakers. With the advice from the folks on here, I picked up a Behringer UB2222 mixer and a Crown XLS 402b power amp. Last night, the bad was getting together for a practice and I wanted to try everything out before we went back to the bar to make sure it all works. All I have to test it is a couple of regular home stereo system Olympus shelf speakers. Approx 1 ft tall. The only info it provides on the back are that they are 8 ohms.
I had a worry that putting all the intruments through those little speakers might blow them out. So I stripped the wires down a bit (typical household stereo cables, nothing like Monster Cables or anything), connected them to the back of the amps 5-way binding posts as the manual instructed I could do, turned everything on and just put the keyboard through first. No prob. After a bit, I added an acoustic guitar. Fine. Then a 2nd guitar. Fine. Then a mic. Fine.
Granted, I wasn't blaring these things and certainly not peaking them (amp was turn on about 1/4 - 1/3 of full pull) but with 2 guitars, a djembe, tin whistles and a keyboard all playing and someone singing (all going through the mixer except the tin whistes and djembe) just the instruments along create quite a loud noise but everyone was able to hear through the speakers. Which I was quite amazed by because these are so small.
The level we were running at is pretty damn near what I run the board at with the FOH bar speakers at during a show. The room we were in at the house was (just a guess and I'm horrible with guessing measurements and age) maybe 10 x 20 w/ hardwood floors.
I know that obviously you dont need huge speakers to fill that small of a space but, here is my actual question (I know, FINALLY! right? hehe)...
Since the band doesn't have any onstage monitors to hear themselves with, do you think these little shelf speakers will hold up ok as onstage monitors for the band? The back of the amp has Speakon outputs which will be used for the house speakers and then these little guys would just be attached to the 5-way binding posts, one for each side.
I guess my concerns are:
1.) During the show, we mic the djembe and I'm worried the low frequencies running through these speakers, even as monitors might effect them.
2.) Wasn't sure if i could use the binding posts at the same time I use the Speakon cable outputs
3.) Will the typical home stereo wiring cause any issues? Unfortunately these are the type of speakers where the wire is hard wired into the speaker box and can't be removed without disassembling the speaker box.
Give me your thoughts if you will.
