Hi everyone.
I've received an old Lexicon FX unit, the LXP-15. The unit is in fairly good condition, but the first thing i noticed is that - Level Settings -aren't working properly. MIX, PAN and OUT values make no changes at all. Only the IN parameter affects dry/wet balance but in a weird way.
I've re-initialized the unit but self-test fails in 2 operations:
1.- ADC 2.- Volatile Ram. ADC failure migth explain this behavior but i'm not really sure of what that means or what component might be faulty.
Volatile Ram refers to Low-Bat i guess. I've checked inside and the battery seems to be soldered to the mainboard?
I'd really like to repair this classy unit. Just in case it's a 1991 1.xx version. (i'm outside USA).
Thanx in advance for your help.
