Hi All,
I have recently got 2x Lexicon Lambda USB units and will be using them on a Windows 7 machine.
I have downloaded the driver software from the Lexicon web-site, version 2.7
When I install the software and run everything goes okay, goes right through and prompts for the restart which I do.
I then plug the USB cable into the PC and it starts installing the drivers.
But, it does not do everything as it put a "X" against one of the unidentified device.
Now I am only guess here, but I believe the USB drivers are installed for the 2 audio port, so it might be the Midi interface that is not installed.
I have tried this on a couple of PC's and it does the same. And it does the same for either of the Lambda units, or different USB sockets.
I also have a Lexicon Alpha and Omega and both of these install without any problems.
I am after some help, support or ideas that can help me out.
Lexicon does not appear to have any support page for questions
Regards Kevin.
Regards Kevin.
