lifelyrics
Training wheels on
Hi Mike,
I'm pasting part of your comment here, so we can hopefully talk about it.
gecko zzed wrote:
Incidentally you refer to dynamic mikes and overloading the DP004. I expect this is not a problem with the mikes, but more a problem with gain structure. 'Gain structure' may not mean much to you now (forgive me if I'm wrong, I really have no knowledge of your technical prowess and I could be wrong), but it's worth making this topic one of your next steps. (If you want to read his entire comment, you can find it @ recording techniques -> Home Recording's Dirty Little Secret -> last page, I believe)
No offense taken. First off, I'd like to say, I love your feedback. You are always informative and insightful.
My understanding of "gain" is simplistic, I'm sure, because I have only used it when I worked in Audacity, and now in Sonar HS 7XL (purchased a month ago - after the recordings for the memorial service). In my terms, it is comparative to whatever else is going on in the mix + or -, therefore I wouldn't even think to use it on a single track, unless the whole thing was too quiet. In audacity, when I ended up with a wav file that was too small for me to see what was going on, I just used "amplify", and then worked from there. I would then adjust gain/pan, etc. to get the right blend with all of my tracks together.
Looking back on it, Hubby thought part of the problem was that we used a low->high impedance converter to go from the XLR to the 1/4" in on our DP, because we were in a time crunch, and had to go with what we had. Would that be a possible reason?
We hadn't even really had time to do much experimenting with the DP before being thrown into the project, since we just got it after Christmas. Then to complicate things, as I said somewhere else, my friend wanted reverb, which isn't in audacity (well, it says it has the effect, but it was unacceptable.) So, we borrowed the church's Mackie mixer (don't remember which one - I think 12 channel), and ran through it to DP. We adjusted gain on the mixer, but had to have everything set so low, I ended up with teeny tiny wav files, which I "amplified" so that I could work with them. I think it's because the mixer acted as a pre-amp, and made the signal too strong for the DP. Is that correct?
So, now we have a proper mic cable if the situation ever arises again, that we need to do vocal tracks on the DP (XLR -> 1/4"). That is how we conducted my mic test the other day - straight to DP, and I found that the input level could be set 1/2 way instead of barely past zero.
This week, my new firewire interface, condenser mic, pop filter, and studio headphones will be arriving, and I will get into that phase of my education - putting all of it together with my SONAR software and my laptop. I'm excited. I love learning. I welcome any additional instruction/information you feel like offering!
