Middleman
Professional Amateur
Defrag your audio drive. Turn off the virtual memory/paging file. Reboot. Delete the pagefile.sys file after the reboot. Defrag 2-3 times. Turn your virtual memory/paging file back on and set it for minimum 2 and maximum 1.5x the amount of ram you have. Reboot.
Make sure you profile your card any time you change the M-Audio buffer settings. If your getting pops, start increasing the M-Audio buffer settings, reprofile in Sonar after each change. Keep going up until they go away.
You can also tweak the buffers in Sonar for fine tuning. I find that once I get the popping out, I then lower the M-Audio drivers one setting. Reprofile and then I fine tune in Sonar and that's where I get the lowest latency without pops.
Disable the onboard sound card and make sure that Windows Media player is set to your M-Audio card for playback. This way you are monitoring your final MP3 or Wave results on the same card. Otherwise, you might find your final mixes sound dramatically different than what Sonar sounds like.
Make sure your picture cache under folder locations is pointing to its own seperate folder.
Do you have the latest drivers for video, audio and Sonar?
That's all I can think of, except buy another hard drive as suggested by others, keep Sonar and all of your audio work on this 2nd drive.
Q.
