Roger,
I would assume that in your software you should be able to configure it to use whatever audio card you desire, as well as midi. Since you know the midi portion is working properly, that should be okay.
I guess where I'm confused is this issue of analog sound versus what? Synthesised sounds? So, you can hear some sounds but not others...this issue in itself is an issue that I may not be able to wrap my head around. If it really is something to do with the audio capabilities of the sound card, okay, we can do something about that. But, you did ask me something that I think I can answer...
You should be able to buy an external soundcard, connecting either via USB, firewire, OR pcmcia for laptops. You can probably find an Edirol interface. You SHOULD be able to configure your software to bypass the onboard card and use the external instead. You SHOULD be able to route the midi to the Edirol seperately. I'm not positive on this, though. Do you have some sort of dialog box with options or settings that can be changed for the cards?
Well, I am quoting this from the website, so I suppose you can...
Simultaneous use of multiple soundcards for both audio and MIDI
I am so sorry if this is insulting your intelligence, because I'm feeling like you are still way ahead of me in terms of the whole recording endeavor, but do you have the Edirol selected as your midi interface in the software already? You must, as I doubt the
Toshiba has any midi capabilities on its own.
If the Korg has midi ins and outs, then it has to have midi capabilities...does it? Yes, it does, I checked.
Here's w hat I found from the Evolution website as well...
A MIDI interface or PC sound card with a MIDI interface. If you want to use Sound Studio Pro II's digital audio facilities, you will need a sound card which supports digital audio. If you wish to operate simultaneous recording and playback of audio, your soundcard should be 'full-duplex' - this means it is able to record audio at the same time as playing back audio and / or MIDI.
so, I still would assume you can do this with a separate audio and midi interface. I'll do some checking for something inexpensive for you and post some links, though you might find better prices than me. I would just make sure that you have all the audio/midi options set right in your software so you don't have to purchase something you don't need to, but an external soundcard with decent capabilities will make a sound difference to you as well.
I'm sorry if I'm dense on this. My keyboard is so old and simple...
Thanks,
Kirstin
