To hear for yourself, go to www.thelisteningsessions.com
I know an SM57 was used for some of the mixes towards the bottom half. It sounded pretty weak to me.
An SM57 will get the job done, and sometimes it will be all the mic you need. I like the E/V ND868 and the ATM25, RE20 is a hell of a kick mic on occassion as well as good at lots of other stuff and junk.
Stick the 57 inside the kick and put another mic outside and you'll get an awesome Red Hot Chilli Peppers BBSM kick sound. As long as the kick is tuned right....
best mics in my experience
1) BEST tie b/w Sennheiser e602 and CAD KBM 412
2nd) tie b/w AKG D112 and Shure Beta52
3rd) any condenser mic (SD or LD) about 1ft in front of kick...
I'm a fan of two mics on the kick. For example, an ATM25 on the beater and a large condenser out in front. Even better is when you have a so-called woofer drum out in front of the bass drum. It seems to give the sense of moving air to the low end. A cheap alternative is to make a little blanket tunnel in front of the bass drum and stick you large condenser in the blanket tunnel.
