Danoforest
The on going mystery of compression. Please suggest a general setup for the Dbx166XL to provide some compression for a Kick Drum in a live sound environment.
Compression on kick at a live gig works great, keeps it in the mix and stops the kick peaking the pa system if the drummer gets carried away.
Fairly quick attack, slower release (need to experiment), hit it hard about 8:1 or 10:1. Set the threshold so that the compressor works fairly hard in during a normal loud kick and it only just works when the kick is hit soft.
Alan.
Three people, three completely different answers. So instead of suggesting a forth thing, I will simply point out that "it depends" is going to be the only real answer. The kick drum, the player, the genre, the room, the pa system, etc... all affect how you would set up the compressor, so without being there, its impossible to tell you how to set it up.
That's more of a safety limiter. I do that sometimes, but mostly I rely on setting the gain correctly.
Im strange, I use compression for the sound more than I use it to even out the dynamics.
