I have a Pacific FS (birch, not laquered) set & haven't gotten a desireable kick drum sound. The Aquarian SuperKick I prepack (batter + resonator) gives the drum a LOT more bass and rumble, but not really any "rich sounding lower mids." It creates more of a modern subwoofer sound instead of a nice harmonic "thump" (sometimes characterized as "muddy mids").
The kick drum still has that annoyingly sharp-bright-earpiercing ATTACK (sounds like "tap! crack!" instead of "boom/thump"). The Superkick I tamed it slightly, but the overall sound is kinda lacking in terms of "musicality & tonality". Some1 recommended an Evans EQ4 batter head to tame the BRIGHT attack and richen the sound since the Aquarian SuperKick series are naturally EQ'd to cut out a lot of the mid frequencies.
I found this chart:
http://www.evansdrumheads.com/bass_spec.asp
is the coated EQ4 the best choice? Or is the clear EQ4 better for my goal? What's the difference between "Open Sound" and "Focused Sound?" The birch wood gives the set a naturally "scooped EQ" & focused sound, but what is a better sounding head to use according to this evans chart?. I would GREATLY appreciate help from all you experienced home reccers!
I found this chart:
