Yep, I've seen it before...
Hi Ray...
I've got a JV-1010 myself... Great Module, eh?
I love the sounds...
Anyway... The problem you are speaking of is answered in the manual... You actually shut off certain MIDI channels so they are not "listening" on the same channels that your other modules are set to... Be sure to read the "online" manual that's on the disk...
Before I say anymore, let me say the easiest way to work with the 1010 is using the accompanying "SoundDiver" software... It works well and can help you cope with the unit more easily than with trying to understand the front panel...
Unfortunately, with
the JV-1010 there is a major drawback with this function... When they designed the 1010 they did not design it to retain ANY of the "Performance Mode" changes that are made... Don't ask why but that's the reason it may not necessarily work with the 1010... If you program the changes you're looking for, shutting off the unit will reset it back to the "Default Performance Setup" - This really stinks because the default performance is set with all 16 MIDI channels set to "on"... There's only a select few parameters that are retained after power off... For a short time, this made the unit practically unusable for me in any other mode other than "Patch" mode... (ie: one channel - one sound)...
The only way to circumvent this is to program your changes into another Performance mode patch and pull that up on each song that you open by calling it up as a "program change" some parameters can also be changed through sys-ex commands... I however only attained limited success with this...
The only other option you have is to set the 1010 on it's own MIDI port... This was my "ultimate" answer... Then the 1010 can happilly run away with all 16 MIDI channels and won't be any 'the wiser' to the other instruments... If you have a "dual-port" interface, this may be the only answer that will yield satisfactory results... Put all the other instruments on the first port and let the 1010 have the second port... OR - buy a 8 port interface (They ARE expensive - I'm using
the AMT8 from Emagic)... That way each MIDI "port" has all 16 channels assigned to it...
I hope this answers a few questions... If you need more help, let me know...
Riverdog
http://www.members.home.com/bkriverdog
