J
jabulani jonny
The title says it all. The seller says it worked perfectly when it left his place. I get it and channel 1 does has no signal, just crackling. The mic and the cable are good. I checked out all other channels with the same mic and cable. I also tried a guitar using a 1/4" cable with the same results. I opened it up, but I don't see anything off hand.
Does anyone have any thoughts as to what it might be? Again, absolutely no signal from the instrument/mic, when you crank the gain there's just noise and crackling. ONLY ON CHANNEL 1. All other channels are fine, clear, no noise, good signal.
Any thoughts on how I might be able to fix this in case he's unwilling to do a return?
Jonathan
Jonathan
