From the manual...
THE MONO/STEREO COMPRESSORS.
The compressors on the 'TwinQ' are an advanced version of the
compressor on the VC1Q. The 5-way slope switch has been improved so
that the effective compression ratios are from approximately 2 to 1 on
position 1 up to a ratio of 15 to 1 on position 5. This high ratio makes the
unit into a limiter.
The attack characteristics have also been improved so that at minimum
attack time, the compression will be fully effective after less than 0.5
milliseconds.
The release system is the same as on the original
Joemeek SC2 which has
a compound release curve: After a single sudden transient signal, the
compression releases extremely quickly. On a normal music signal the
compression releases at a speed according to the release control.
NOTE. When both attack and release are set to maximum speed (both fully
anti-clockwise), the speed of the circuit action is very much quicker than is
possible to show on conventional meter movements, so the meters cannot
register the amount of transient compression accurately.
STEREO OPERATION
When the 'link' switch is depressed (yellow light on) and the compressors
are both selected 'on', the left-hand compressor becomes the master in all
respects: The compression control, the slope, the attack and the release
act on both channels. The left-hand meter gives an indication of the
amount of compression on both channels.
NOTE. When operating in 'stereo' mode, if the right-hand meter is switched
to read compression, it will only indicate correctly if the right-hand slope
switch is selected to the same slope as the master left-hand switch.
It is recommended that when working in stereo mode, the right-hand meter
is left switched to reading the audio level at all times.
twinQCS Dual Recording Channel - User's guide
