Thanks Ron82. I've just tested it out but I'm still doing something wrong. I turned all the red knobs on the board hard left and ended up with no sound coming through the headphones. To get sound I had to turn channel 1 Aux fx up to 12 o'clock. As well as the aux fx at 12 oclock above the main mix and alt 3/4 sliders. So I could hear sound then, and i got a sound wave in cubase after recording but no sound on playback at all!
My mic is plugged into to channel 1.
The gain is turned up to 3 o'clock. Haven't touched the eq's - all at 12 o'clock, aux (1) is turned hard left - it's pre button is out (what's this button for?), the aux (2)fx is up to 12 o'clock (so I can get sound - which is normal with no reverb in the phones..at this stage), pan knob centred, mute button untouched too, solo button on channel slider untouched and slider up to o.
Then on channel 7/8 the slider is also up to o with the mute switch on and everything else untouched. Next, ALT 3/4 slider's are up with aux fx at 12 and it's solo button pressed in. If it's left out, there is hell reverb!! Under this aux is three buttons. Tape, ALt 3/4, and main mix. When recording the tape button is out along with the alt 3/4 and the main mix pressed in. Everything else on the desk is left alone. But on play back, I have to press in the alt 3/4 switch.
My God!!! I can't believe I just got that all out! I really do apologise for being so basic here. I visit other forums trying to get answers for my own questions but as you can see, I'm still learning the language and terminology. I don't care much for either....I just want to record my songs!! (sigh of desperation!)
But yes, I know. I should make an effort to understand the language so that I can at least communicate my problems easier to all you guys!!!
Thank you for all your time it has taken for you to read this and big hugs if you can help!
Nassa
Nassa
