Hey!
I'm planning on buying a Rode NT1-A mic. Problem is my room is very loud due to my PC.
There's 2 options:
1) Get quiet fans
2) Isolate the computer
I don't want to move the computer because you can hear it across the whole room. Now there is a closet I was thinking of putting it in, but heat would build up extremely quickly and it's 20+ feet away (firewire would be tough with latency problems - and I don't know where I can find cables that are that long).
The computer currently has a liquid cooling system on it. I can't downgrade cooling ability because the computer has to be able to handle heavy video editing. I maybe could get some quieter fans but not sure if I'd be better off spending it on the 2nd option, isolating.
I've thought of ideas how to do this and I'm not really sure if it will work. I want to make a box for the computer to go in that is completely sealed except for a cable hole (which would be sealed tightly) and a vent/exhaust. The vent would keep fresh air flowing in and the exhaust to let air out. Long tubing running out of the room (OR into the return vent from the central air?) with some powerful fans would really get the air moving through the box.
The more I think about it, the more I question it. I want to do this right, lining the box with foam would most likely help. There needs to be a door so I can access the computer drives and buttons that when closed would seal completely air tight and sound tight.
I'd have to find some vent fans and figure out what kind of tubing to use.
Any ideas? This might be a lost cause project...
There's 2 options:
1) Get quiet fans
