Is there truth in this
  • Thread starter Thread starter BLP
B
BLP
I was reading and they say a good chain to help mastering a whole project in a DAW setting is EQ > COMPRESSOR > LIMITER
I can use this chain on each track to get the percieved loudness meter around my favorite tracks.
I've been working with this and it seems to be helping.
I use the eq to have a low cut off and boost mids or highs
(if needed but very small changes from .1-2db)
then a compresser
(manualy adjusting the input to where my VU meter is average around 3db
then adjusting attack, release, output as needed)
then the limiter as needed by ear with output set at -.01dB
This is just a small step into mastering but am I getting a good idea of it?
If your understanding of "mastering" is "loud" then yes. "Loud" is the easy part.
No. My understanding of mastering is not loud. These are the steps I was using to have all the songs even in perceived loudness throughout whole cd and keeping everything under 0dB at same time. I was asking if this is a good way to go at it?
That's not a bad start for getting the songs to have continuity in eq balance and level.
You mention setting the ceiling at -.01. You probably meant -.1 dBFS and I would recommend around -.3 dBFS.. It's not like those tenths of a dB or going to make a huge difference, but this will help in preventing overs in some situations like mp3 conversion....and don't forget to dither as the step usually following limiting.
Who, guys,
He said:
"I can use this chain on each track to get the perceived loudness meter around my favorite tracks."
I don't think it's a good idea to crank each track up as loud as possible before you mix.
But maybe that's just me.
Who, guys,
I think by "track", he meant "song".
I think you should try to get the average level somewhere in the -5dbfs range or else no one will like your music.
Who, guys,
I meant song. Sorry bout that.
I'm having the urge to change the dynamics of every track while mastering a whole project. TO ME it sounds better, but I might be wrong.
Yes RMS is the average level (or at least one way of calculating an "average"). It is actually a methodology for attributing a DC equivalent voltage to a given AC signal.
Anytime that you apply limiting or compression the dynamics will change. Adding eq will not effect the dynamics so much as it effects the frequency balance. I find it more useful to get that in order most of the time before any dynamics processing.
Why are you posting in this thread if you don't plan to give real advice?
How do you know he doesn't plan to give real advice? He may be building towards it real slow-like.
I do have some advice for you.....
Smile. Lighten up. Life is too short to be all clenched.
