cincy_kid
Active member
First off, sorry if I posted this in the wrong forum heading, but I figured since it had to do with my studio configuration, this may be the best place
So, my desk where I will mix is now like 30 foot from the closet that i will be actually recording in. So instead of stretching the mic cords from the closet to mix area / preamp, I figured I would buy a snake that could act as an extension cord and plug into my preamp or board or wherever (depending on my chain setup) and then run the snake into the recording room and plug the mic(s) into it there. Also, there's the headphones. The snake I was looking at has a 1/4" slot for the headphones so I can do the same thing basically (plug the snake's 1/4" into the board and then plug the headphones into the snake in the closet).
Here are the questions:
1) Will the snake idea work and is it the best/easiest way to achieve the stretch for my situation?
2) What if I want to have more than 1 headphones? For example, lets say I have someone in the closet recording with headphones on and I am at the mix desk and I want to have headphones on too, or even 2 people in the closet with each a pair of headphones on. The snake only has 1 of the 1/4" things so is there something else I need to buy like a headphone amp or is there an easier solution?
keep in mind, this will mostly be for myself but once in a while I may have a buddy over to mess around with some tunes, so 2 headphone possibilities would be nice to have.
Thanks in advance ~
Thanks in advance ~
