Hey all,
I think I've got a pretty good concept of the types of things that most of the posts here are about. I'm not saying I'm particularly good at any of it, but I do think I at least have a basic understanding of Mastering at the artistic level, but less so at the more technical level: preparing the actual audio for the final medium.
In particular, this started off when I saw this post a few months ago:
These are all great questions to me, since I'm kind of in the dark about the nitty-gritty aspects of a lot of them. So I'm hoping maybe we can talk about this kind of stuff?
For the record, I did pick up a copy of Bob Katz's book already. I read through (some parts twice or more) and it had some good information, but a lot of it was also directed to the artistic side of things, and I don't know that the more technical aspects really "stuck" in my brain. If anybody can point me to some good links about the medium preparation (not necessarily just for CD either), that'd be swell. Free/online resources are always preferred, but if you know of a "must-have" book then don't be shy about it.
Just for some context of this post, I recently worked a session for a band and they also asked me to mix/master (I realize this isn't the best policy, but this was more for fun/learning than any top-notch commercial endeavor), and had to do a little bit of research into this sort of stuff. What I found was that I know f-all in terms of the technical aspects of mastering.
Take PQ Codes. All I really know about PQ codes is that they determine how the CD is structured in terms of track number, track length, and transitions.
I didn't have a "stock" answer to how to handle this. In terms of generating the final disc, I ended up importing all the finished songs into a session in Sonar and burned out one long continuous file. Then I used Sonar to find the points between tracks where I wanted the crossover to happen, and took note of the exact time code info for those points. Then I made up a CUE sheet and used CDBurnerXP to put it together. I have used Nero in the past (minus CUE sheet part), but found that some players had issues with truly "seamless" transitions between tracks when I did. So far I think this new strategy worked, but I haven't gotten to test it on some players I knew were a problem before (either they stopped working or I no longer have access to them).
As for C1/C2/CU errors (another part of SSG's post that made me realize how little I knew), all I can really say about them is that they're not normally detectable by listening and ideally they each should be on the order of 0-10 errors/minute (I think?). I don't really know what the different errors indicate though, and my detection/insurance against them was basically burning at a slow speed and crossing my fingers.
I don't do a lot of mastering, but I'm definitely still up to learn more about the process, and I think this is the area where most people really don't know how much they don't know. So any advice/tips/pointers/sagely wisdom is appreciated.
Thanks!
Fala, do you mind if I ask you a few questions about your mastering technique and process? (Everybody else, shhhhh! )
1. What do you use to do your PQ code editing?
2. How do you generate your disc error list?
3. How do you generate your track list?
4. What do you feel is the proper ratio of C1 to C2 to CU errors on the premaster?
5. How do you determine track order?
6. How do you determine the reference or guide amplitude to adjust the songs to?
and finally
7. What is mastering?
G.
Thanks!
