Editor
OK, short story to explain. I have an old No-Name Strat copy ... had to sell my REAL Strat & Les Paul & Marshall (long story ... involves paying a mortgage and a woman ;-) ...that I am trying to coax some life out of.
Even though I have been out of the music picture ,as it were, for a while now, I still have the urge to PLAY! I refinished the wood, redid the wiring & pickups...put in a single coil bridge, single coil centre and a humbucker in the bridge position-- looks good to me & the wiring works fine.
Problem: Last week, I disassembled everything to do the wiring...put it back together ... new strings ... set up the intonation .. check the wiring ... everything good. Decided to throw in a humbucker in the centre position so I took everything apart. Put it back together. New strings ... intonation seems good ... BUT ...
... now when I fret a note on any string, I hear a second overtone that seems to be a semitone below the fretted one ... very sour ... YUCCCHHH!
It may have always sounded this way but since I did a pretty good job of shielding (see GUITARNUTS.COM), I am now getting a lot more tone (& overtone) out of the beast.
I set the action quite a bit higher than I am used to and made sure the strings are not contacting the pickup covers ... all the obvious things... but no improvement. The neck looks bowed ... not warped ... very high action around the 12th fret & low around the 1st.
I am thinking I should try shimming the bolt-on neck joint before playing with the truss rod to try & get rid of the extra overtone. Good idea? Anything else I should look for?
Chris
Chris
