I recently started tracking vocals with an M audio Fast Track USB interface.
The interface only has two LED indicator lights, which is kind of a hassle.
A Green led, and RED led, which comes on when I'm clipping or about to clip.
When tracking my vocals in my DAW, I found a comfortable fader level, which works well with my dynamic range (without having to use hardware or software compression).
MY PROBLEM:
Within my DAW, there is rarely any clipping when I record. (I usually set my between -4 and -7)
However, the red led indicator on my interface is constantly coming on, even if I'm nowhere near clipping in my DAW.
Even when I engage the -10dB pad on my mic, the RED LED still comes on!
I'm using the fastrack's built in gain/preamp knob, which is really just a shoddy variation between "on" and "off"
(there's not much of a "gain" variety)
MY QUESTION:
Basically, can clipping in my interface corrupt my track, even though my DAW doesn't show any clipping?
Like, will my track be corrupted before it even enters my DAW?
I don't actually hear clipping or distortion, but that RED LED is just a constant nuisance!
Would using a different preamp before my fast track be of any help?
(Any USB fast track users...this is the low end model that comes with M-Powered -__-)
Any tips, suggestions?
My current set up is as follows: Sterling Audio St59 > Nady Phantom power > M Audio fast track (built in preamp) > Logic Pro
MY PROBLEM:
MY QUESTION:
