scottn5388
I have a question about how to integrate a Delta 1010, a headphone amp (Behringer HA4700), a monitoring system, and a few preamps. I’m hoping I’ll be able to describe this thoroughly enough so that you all understand it, but I may end up attaching a drawing if all does not go well. This is the way I currently have it all set up:
-Preamp outs run directly to the Ins (1 through 8) of the Delta 1010
-Outs 1&2 of Delta 1010 to monitoring system (A small mixer à Power Amp à monitors)
-Outs 3&4 of Delta 1010 to headphone amp (feeding 4 sets of headphones)
-In the Delta control panel, I have Out 1&2 routed to the “monitor mixer” so that I can hear both the tracks that have already been recorded, and the sound coming from the preamps.
So say I’m overdubbing with a mic running into one of the preamps and then on to Input 1 on the Delta 1010. I can hear what’s already been recorded in both the monitors and the headphones (Outputs 1-4), but I can only hear the source from the preamps in the monitors, not the headphones.
Is there a way to set it up so that both the pre-recorded tracks, and the source from the preamps can be heard in both the monitors (Outs 1&2) and the headphones (Outs 3&4)? It seems as though I can only route the Monitor Mixer output of the Delta 1010 to Outs 1&2. Is there any way around this?
Thanks,
Scott
Thanks,
Scott
